주요 콘텐츠로 건너뛰기
Samsung SPH-A500 Front LCD Display Replacement
필요한 것
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: 1 단계, 이미지 1/1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: 3 단계, 이미지 1/1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: 4 단계, 이미지 1/1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: 5 단계, 이미지 1/1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: 6 단계, 이미지 1/1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: 7 단계, 이미지 1/1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
결론
Derek Panger
회원 가입일: 04/16/10
21 평판
안내서 1개 작성함
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G100
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,441
