주요 콘텐츠로 건너뛰기
Samsung SPH-A500 Keypad Replacement
필요한 것
  1. Samsung SPH-A500 Keypad Replacement, Keypad: 1 단계, 이미지 1/1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Keypad Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Keypad Replacement: 3 단계, 이미지 1/1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Keypad Replacement: 4 단계, 이미지 1/1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Keypad Replacement: 5 단계, 이미지 1/1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
  6. Samsung SPH-A500 Keypad Replacement: 6 단계, 이미지 1/1
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
  7. Samsung SPH-A500 Keypad Replacement: 7 단계, 이미지 1/1
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
  8. Samsung SPH-A500 Keypad Replacement: 8 단계, 이미지 1/1
    • Replace the keypad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick Dominikovic
회원 가입일: 04/13/10
139 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G100
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,800
