주요 콘텐츠로 건너뛰기
Samsung SPH-A500 Speaker Replacement
필요한 것
  1. Samsung SPH-A500 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: 2 단계, 이미지 1/1
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: 3 단계, 이미지 1/1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: 4 단계, 이미지 1/1
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: 7 단계, 이미지 1/1
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick Dominikovic
회원 가입일: 04/13/10
139 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G100
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 2,345
