주요 콘텐츠로 건너뛰기
Samsung SPH-A760 Speakers Replacement
필요한 것
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: 1 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: 1 단계, 이미지 2/2
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: 2 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: 2 단계, 이미지 2/2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: 3 단계, 이미지 1/1
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: 4 단계, 이미지 1/1
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: 5 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement: 5 단계, 이미지 2/2
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: 6 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement: 6 단계, 이미지 2/2
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: 7 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement: 7 단계, 이미지 2/2
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: 8 단계, 이미지 1/2 Samsung SPH-A760 Speakers Replacement, Speakers: 8 단계, 이미지 2/2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: 9 단계, 이미지 1/3 Samsung SPH-A760 Speakers Replacement: 9 단계, 이미지 2/3 Samsung SPH-A760 Speakers Replacement: 9 단계, 이미지 3/3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: 10 단계, 이미지 1/3 Samsung SPH-A760 Speakers Replacement: 10 단계, 이미지 2/3 Samsung SPH-A760 Speakers Replacement: 10 단계, 이미지 3/3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
결론
David
회원 가입일: 04/19/10
25 평판
안내서 6개 작성하였습니다
Cal Poly, Team 10-43, Garner Spring 2010 Cal Poly, Team 10-43, Garner Spring 2010 회원
CPSU-GARNER-S10S10G43
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 1,941
