주요 콘텐츠로 건너뛰기
Samsung SPH-M360 Battery Replacement
  1. Samsung SPH-M360 Battery Replacement, Battery: 1 단계, 이미지 1/3 Samsung SPH-M360 Battery Replacement, Battery: 1 단계, 이미지 2/3 Samsung SPH-M360 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Battery Replacement: 2 단계, 이미지 1/3 Samsung SPH-M360 Battery Replacement: 2 단계, 이미지 2/3 Samsung SPH-M360 Battery Replacement: 2 단계, 이미지 3/3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
결론
To reassemble your device, follow these instructions in reverse order. Be sure to place the side of the battery showing two small arrows in first, with the arrows showing and pointing towards the bottom end of the phone.
Hunter Parker
회원 가입일: 10/22/15
475 평판
안내서 4개 작성하였습니다
University of Memphis, Team 3-5, Kim Fall 2015 University of Memphis, Team 3-5, Kim Fall 2015 회원
UM-KIM-F15S3G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 208
