주요 콘텐츠로 건너뛰기
Samsung SPH-M360 Case Replacement
필요한 것
  1. Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: 1 단계, 이미지 1/2 Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: 1 단계, 이미지 2/2
    • Detach the battery cover by sliding the cover down toward the bottom of the phone.
    • Slide back cover in direction of arrow.
    • Lift up on the battery cover to complete cover removal.
  2. Samsung SPH-M360 Case Replacement, Remove the battery.: 2 단계, 이미지 1/2 Samsung SPH-M360 Case Replacement, Remove the battery.: 2 단계, 이미지 2/2
    • Remove battery by lifting up in the corner of the battery.
    • Use the semi-circle provided in order to gain access to the battery.
    • Battery will come out at an angle. This does not require force.
  3. Samsung SPH-M360 Case Replacement, Unscrew the case: 3 단계, 이미지 1/1
    • Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
    • Note: keep the screws in a safe location, where they will not be lost until needed for reassembly.
  4. Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 4 단계, 이미지 1/3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 4 단계, 이미지 2/3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 4 단계, 이미지 3/3
    • Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
    • There is a small clip at the top of the phone that must be released in order to remove the back case.
    • The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
    • REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
결론
Tyler Long
회원 가입일: 10/06/14
109 평판
안내서 1개 작성함
Plato Plato 회원
Community
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 214
