주요 콘텐츠로 건너뛰기
Samsung SPH-M360 Keyboard Replacement
필요한 것
  1. Samsung SPH-M360 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Samsung SPH-M360 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Samsung SPH-M360 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Keyboard Replacement: 2 단계, 이미지 1/3 Samsung SPH-M360 Keyboard Replacement: 2 단계, 이미지 2/3 Samsung SPH-M360 Keyboard Replacement: 2 단계, 이미지 3/3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Keyboard Replacement, Casing: 3 단계, 이미지 1/1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Keyboard Replacement: 4 단계, 이미지 1/2 Samsung SPH-M360 Keyboard Replacement: 4 단계, 이미지 2/2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Keyboard Replacement: 5 단계, 이미지 1/2 Samsung SPH-M360 Keyboard Replacement: 5 단계, 이미지 2/2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/1
    • Flip open the phone so that the text on the keyboard is visible.
    • Push from the text side until the keyboard comes completely out of the phone casing.
결론
Hunter Parker
회원 가입일: 10/22/15
475 평판
안내서 4개 작성하였습니다
University of Memphis, Team 3-5, Kim Fall 2015 University of Memphis, Team 3-5, Kim Fall 2015 회원
UM-KIM-F15S3G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 91
