주요 콘텐츠로 건너뛰기
Samsung SPH-M360 Logic Board Replacement
필요한 것
  1. Samsung SPH-M360 Logic Board Replacement, Battery: 1 단계, 이미지 1/3 Samsung SPH-M360 Logic Board Replacement, Battery: 1 단계, 이미지 2/3 Samsung SPH-M360 Logic Board Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Logic Board Replacement: 2 단계, 이미지 1/3 Samsung SPH-M360 Logic Board Replacement: 2 단계, 이미지 2/3 Samsung SPH-M360 Logic Board Replacement: 2 단계, 이미지 3/3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Logic Board Replacement, Casing: 3 단계, 이미지 1/1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Logic Board Replacement: 4 단계, 이미지 1/2 Samsung SPH-M360 Logic Board Replacement: 4 단계, 이미지 2/2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Logic Board Replacement: 5 단계, 이미지 1/2 Samsung SPH-M360 Logic Board Replacement: 5 단계, 이미지 2/2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Logic Board Replacement, Logic Board: 6 단계, 이미지 1/1
    • Use the plastic opening tool to gently detach the golden strip from the logic board.
    • The strip should detach easily with little force required.
  7. Samsung SPH-M360 Logic Board Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
  8. Samsung SPH-M360 Logic Board Replacement: 8 단계, 이미지 1/2 Samsung SPH-M360 Logic Board Replacement: 8 단계, 이미지 2/2
    • Flip the logic board over and locate the three screws along the edges.
    • Carefully unscrew the three screws to remove the panel covering the logic board.
    • Be careful with the screws after unscrewing them because they are small and easy to lose.
  9. Samsung SPH-M360 Logic Board Replacement: 9 단계, 이미지 1/2 Samsung SPH-M360 Logic Board Replacement: 9 단계, 이미지 2/2
    • Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board.
    • This will not require much force, so be gentle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashraf Nasser
회원 가입일: 10/22/15
126 평판
안내서 1개 작성함
University of Memphis, Team 3-5, Kim Fall 2015 University of Memphis, Team 3-5, Kim Fall 2015 회원
UM-KIM-F15S3G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 210
