필요한 것
Locate the arrow on the panel of the rear side of the phone.
Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
Use the plastic opening tool to gently detach the golden strip from the logic board.
The strip should detach easily with little force required.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
