주요 콘텐츠로 건너뛰기
Samsung ST700 Battery Replacement
필요한 것
  1. Samsung ST700 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • The battery is located on the bottom of the camera underneath a latch door
    • To open the latched door, move the latch (circled in the picture) toward the center of the camera, and the door should pop open.
  2. Samsung ST700 Battery Replacement: 2 단계, 이미지 1/1
    • When the bottom componets are exposed, the battery is held by a blue latch. (Blue latch is circled in the picture)
    • Push the blue latch latch to relase the battery from its slot. It should be pushed out.
    • Remove the battery.
    • Move the blue latch to put in the new battery.
    • Make sure that the battery is going in the correct way. The three golden slits should be matching up with three golden prongs on the bottom of the battery holder.
    • Close the latch door over the components and move the latch toward the side of the camera. Trying turning on the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tanner Studley
회원 가입일: 03/04/16
125 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-4, Bhusal Spring 2016 UMass Dartmouth, Team 6-4, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G4
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
my baterry inflated with air and now is stuck in the slot, what should i do?
Denix 54 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 455
