주요 콘텐츠로 건너뛰기
Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement
필요한 것
  1. Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement: 2 단계, 이미지 1/2 Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement: 2 단계, 이미지 2/2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement: 3 단계, 이미지 1/2 Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement: 3 단계, 이미지 2/2
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement, 16 GB SanDisk: 4 단계, 이미지 1/3 Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement, 16 GB SanDisk: 4 단계, 이미지 2/3 Samsung Series 5 3G Chromebook 16 GB SanDisk Replacement, 16 GB SanDisk: 4 단계, 이미지 3/3
    • Remove the single screw.
    • use the plastic tool to disconnect the WWAN antennas from the board.
    • After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Helder Avelino
회원 가입일: 10/22/13
938 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-7, Shastany Fall 2013 University of Maryland, Team 1-7, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G7
2 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,162
