주요 콘텐츠로 건너뛰기
Samsung Series 5 3G Chromebook Back Cover Replacement
필요한 것
  1. Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Back Cover Replacement: 2 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Back Cover Replacement: 2 단계, 이미지 2/2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Back Cover Replacement: 3 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Back Cover Replacement: 3 단계, 이미지 2/2
    • Once you work your way around, you can remove the panel.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Helder Avelino
회원 가입일: 10/22/13
938 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-7, Shastany Fall 2013 University of Maryland, Team 1-7, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G7
2 회원들
안내서 9개 작성하였습니다
댓글 한 개
If anyone was wondering about putting the shampoo in the same bag as your Chromebook…don't! I'm just going from the house to the man cave (maybe 100 feet). A couple hours later I remember charge the chrome…and F
Chris Goh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 13,401
