주요 콘텐츠로 건너뛰기
Samsung Series 5 3G Chromebook Battery Replacement
필요한 것
  1. Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Battery Replacement: 2 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Battery Replacement: 2 단계, 이미지 2/2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Battery Replacement: 3 단계, 이미지 1/2 Samsung Series 5 3G Chromebook Battery Replacement: 3 단계, 이미지 2/2
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook Battery Replacement, Battery: 4 단계, 이미지 1/3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: 4 단계, 이미지 2/3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Remove three Phillips screws from the battery.
    • Disconnect the battery from the motherboard.
    • Lift the battery up and away from the laptop to remove it.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Helder Avelino
회원 가입일: 10/22/13
938 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-7, Shastany Fall 2013 University of Maryland, Team 1-7, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G7
2 회원들
안내서 9개 작성하였습니다
댓글 한 개
i want the chromebook battery
Christopher Jorgensen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 19,226
