주요 콘텐츠로 건너뛰기
Samsung Series 5 UltraTouch Battery Replacement
필요한 것
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: 1 단계, 이미지 1/2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: 1 단계, 이미지 2/2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
    The user manual recommends, before removing the cover:
    "Insert an object, such as a paper clip, into the Emergency Hole at the bottom of the computer to cut the battery power. If the Power button does not work anymore, that means you successfully shut the power off."
    This seems to make sure power is completely off or something. The hole can be seen in the picture; it is located in the center, very near where the screwdriver is.
    Pachi - 답글
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: 2 단계, 이미지 1/2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: 2 단계, 이미지 2/2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: 3 단계, 이미지 1/2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: 3 단계, 이미지 2/2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: 4 단계, 이미지 1/2 Samsung Series 5 UltraTouch Battery Replacement: 4 단계, 이미지 2/2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: 5 단계, 이미지 1/1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: 6 단계, 이미지 1/1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: 7 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Timothy
회원 가입일: 01/30/15
1,579 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-3, Watkins Winter 2015 USF Tampa, Team 16-3, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - 답글
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 44
전체 시간: 26,754
