주요 콘텐츠로 건너뛰기
Samsung Series 5 Ultrabook RAM Replacement
필요한 것
  1. Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: 1 단계, 이미지 1/2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: 1 단계, 이미지 2/2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: 2 단계, 이미지 1/2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: 2 단계, 이미지 2/2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: 3 단계, 이미지 1/2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: 3 단계, 이미지 2/2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook RAM Replacement: 4 단계, 이미지 1/2 Samsung Series 5 Ultrabook RAM Replacement: 4 단계, 이미지 2/2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook RAM Replacement: 5 단계, 이미지 1/1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook RAM Replacement, Remove the Battery: 6 단계, 이미지 1/1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook RAM Replacement: 7 단계, 이미지 1/1
    • Remove the battery from the laptop.
  8. Samsung Series 5 Ultrabook RAM Replacement, RAM: 8 단계, 이미지 1/3 Samsung Series 5 Ultrabook RAM Replacement, RAM: 8 단계, 이미지 2/3 Samsung Series 5 Ultrabook RAM Replacement, RAM: 8 단계, 이미지 3/3
    • Use a spudger (or your fingers) to unhinge the left and right clips holding the RAM in place.
  9. Samsung Series 5 Ultrabook RAM Replacement: 9 단계, 이미지 1/1
    • Carefully remove the RAM when both tabs have been fully disengaged.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Javier Jimenez
회원 가입일: 11/04/19
223 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G6, Harley Fall 2019 IUPUI, Team S1-G6, Harley Fall 2019 회원
IUPUI-HARLEY-F19S1G6
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 25
전체 시간: 1,515
