주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Proving once again that thin and light can still be repairable when thoughtfully designed, the Series 9 15" scores a near-perfect 9 out of 10.
  1. Reference shots. Reference shots. Reference shots.
    • Reference shots.
  2. Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off. It's clipped in along the back edge but not very strongly.
    • Opening procedure is piece of cake. Remove 10 Phillips screws and lift the rear panel off.
    • It's clipped in along the back edge but not very strongly.
    • Internal view.
    • This is seriously cool. From here we can remove: SSD, RAM, battery, right speaker, display assembly, wireless card, (modular!) headphone jack and thermal assembly.
    • That's pretty much everything you'd ever want to tinker with in a laptop. The only commonly-replaced components we can't reach is the keyboard, trackpad, and motherboard.
  3. To keep things uniform, we're starting with the battery. It's held in with seven Phillips screws and comes out in a flash.
    • To keep things uniform, we're starting with the battery.
    • It's held in with seven Phillips screws and comes out in a flash.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. We then start picking parts off the motherboard and the peripheries. Along the way, we discover room for not one, but two RAM modules. That addition, along with the standard, removable SSD means this laptop is super upgradable.
    • We then start picking parts off the motherboard and the peripheries.
    • Along the way, we discover room for not one, but two RAM modules.
    • That addition, along with the standard, removable SSD means this laptop is super upgradable.
  6. We could remove the motherboard at this point, but pause to take a look at this trackpad. Seemingly held in place with just five screws, but we remove them and it won't budge.
    • We could remove the motherboard at this point, but pause to take a look at this trackpad.
    • Seemingly held in place with just five screws, but we remove them and it won't budge.
    • Then we peel off this pair of taped-in brackets, pry from the top bracket, and successfully remove the trackpad assembly.
  7. Next up is the fan. It's secured with two screws. And the daughterboard. After unscrewing three Phillips screws it will not budge, so we had to break up the adhesive holding it in.
    • Next up is the fan. It's secured with two screws.
    • And the daughterboard. After unscrewing three Phillips screws it will not budge, so we had to break up the adhesive holding it in.
  8. Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge. Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge.
    • Motherboard removal. Pretty straightforward as long as you remember to clear the standoff pins on the far right edge.
  9. Finally we remove three screws from each of the display hinges and the display assembly is free. Finally we remove three screws from each of the display hinges and the display assembly is free.
    • Finally we remove three screws from each of the display hinges and the display assembly is free.
  10. The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): All screws are Phillips screws.
    • The Samsung Series 9 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • All screws are Phillips screws.
    • RAM, SSD, and battery are all easily replaced.
    • Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
    • A moderate amount of adhesive on the I/O board and trackpad brackets complicates some reassembly procedures.
    • Manufacturer does not provide user-accessible repair documentation.
결승점
다른 7명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 2015년 02월 05일
183,911 평판
안내서 178개 작성하였습니다
iFixit iFixit 회원
Community
107 회원들
안내서 10,265개 작성하였습니다
how would one repair water vapor trapper in between the touch panel glass?
cooperbeaman - 답글
Sadly when you pulled back the bezel you missed that it’s not a separate LCD but part of the top cover those screws at the bottom just hold a panel in place at the bottom.
Good guide otherwise.
Gaspard Leon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 47
30일 전: 226
전체 시간: 7,188
