주요 콘텐츠로 건너뛰기
Samsung Series 9 NP900X3A Back Panel Replacement
필요한 것
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: 3 단계, 이미지 1/3 Samsung Series 9 NP900X3A Back Panel Replacement: 3 단계, 이미지 2/3 Samsung Series 9 NP900X3A Back Panel Replacement: 3 단계, 이미지 3/3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
결론
Zahir Sanchez
회원 가입일: 02/08/18
493 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,141
