소개
If your computer is no longer holding a charge or is dying quickly without a charger, then you should replace the battery. This guide will help you replace the battery.
필요한 것
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Where’s the best place to purchase an original replacement battery for this model: NP900X3A
email:
Best Email: Only related to this product SAMSUNG Model: NP900X3A.
cotodecaza@gmail.com
Thank You,
Giancarlo
