소개
Remove if you have damaged the USB , AUX , or HDMI port.
필요한 것
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
To reassemble your device, follow these instructions in reverse order. If the replacement does not fix your problem, you may have a motherboard problem that will require a software dignostic.
다른 한 분이 해당 안내서를 완성하였습니다.
