주요 콘텐츠로 건너뛰기
Samsung Series 9 NP900X3C-A02US Touch Pad Replacement
필요한 것
  1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement, Touch Pad: 1 단계, 이미지 1/1
    • Shut down the laptop.
    • Power off the laptop by navigating the window icon on the bottom left and clicking on the power followed by shutdown.
  2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 2 단계, 이미지 1/2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 2 단계, 이미지 2/2
    • Remove the back cover of the laptop by using a Phillips #00 screwdriver to remove ten 2 mm screws.
    • Pry out the bottom panel on all sides using a prying tool.
  3. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 3 단계, 이미지 1/3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 3 단계, 이미지 2/3 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 3 단계, 이미지 3/3
    • Unscrew the internal battery and disconnect it from the motherboard.
    • Remove all the cables, tapes by using the tools such as plastic spudgers.
    • Look for the ribbon cable connection and by using the spudger to pull up the clip and unlock the ribbon cable.
  4. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 4 단계, 이미지 1/2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 4 단계, 이미지 2/2
    • Peel out any tapes holding the touchpad carefully.
  5. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 5 단계, 이미지 1/2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 5 단계, 이미지 2/2
    • By using the prying tool unstick and detach the module.
  6. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 6 단계, 이미지 1/2 Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: 6 단계, 이미지 2/2
    • Remove four 0.1mm screws using a Phillips #00 Screwdriver from the laptop.
    • Open the laptop a little bit to create space to drop the touchpad module by pushing it gently downwards.
    • After taking out the touchpad clean it especially at the edges and the corners by using rubbing alcohol and microfiber cloth.
결론
Ghaniyah Gul
회원 가입일: 02/07/23
391 평판
안내서 2개 작성하였습니다
Gateway, Team A-2, Gonzalez Spring 2023 Gateway, Team A-2, Gonzalez Spring 2023 회원
GCC-GONZALEZ-S23SAG2
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 153
