주요 콘텐츠로 건너뛰기
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: 3 단계, 이미지 1/1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
결론
Austin
회원 가입일: 07/11/13
201 평판
안내서 2개 작성하였습니다
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 10
전체 시간: 293
