주요 콘텐츠로 건너뛰기
Samsung Star Touch Screen Replacement
필요한 것
동영상 개요
  1. Samsung Star Touch Screen Replacement, Touch Screen: 1 단계, 이미지 1/3 Samsung Star Touch Screen Replacement, Touch Screen: 1 단계, 이미지 2/3 Samsung Star Touch Screen Replacement, Touch Screen: 1 단계, 이미지 3/3
    • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  2. Samsung Star Touch Screen Replacement: 2 단계, 이미지 1/3 Samsung Star Touch Screen Replacement: 2 단계, 이미지 2/3 Samsung Star Touch Screen Replacement: 2 단계, 이미지 3/3
    • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  3. Samsung Star Touch Screen Replacement: 3 단계, 이미지 1/3 Samsung Star Touch Screen Replacement: 3 단계, 이미지 2/3 Samsung Star Touch Screen Replacement: 3 단계, 이미지 3/3
    • Unstuck camera keys and remove the middle bezel.
  4. Samsung Star Touch Screen Replacement: 4 단계, 이미지 1/2 Samsung Star Touch Screen Replacement: 4 단계, 이미지 2/2
    • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  5. Samsung Star Touch Screen Replacement: 5 단계, 이미지 1/3 Samsung Star Touch Screen Replacement: 5 단계, 이미지 2/3 Samsung Star Touch Screen Replacement: 5 단계, 이미지 3/3
    • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  6. Samsung Star Touch Screen Replacement: 6 단계, 이미지 1/2 Samsung Star Touch Screen Replacement: 6 단계, 이미지 2/2
    • Now is easy to remove the touch screen.
  7. Samsung Star Touch Screen Replacement: 7 단계, 이미지 1/3 Samsung Star Touch Screen Replacement: 7 단계, 이미지 2/3 Samsung Star Touch Screen Replacement: 7 단계, 이미지 3/3
    • Install new touch screen and assembly the phone.
결론
다른 10명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,182 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,520개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 3,822
