주요 콘텐츠로 건너뛰기
소개
This guide was intended to be a prerequisite guide.
  1. Using your fingers, pry along the groove at the top of the phone.
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
  2. With your fingers, pry from the bottom of the battery to loosen it.
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
  3. Locate the red and white sim card located above the battery housing.
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
  4. Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
  5. Pry around the rear panel with a plastic opening tool to loosen it.
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
  6. Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
  7. Locate the flex cable attachment at the tab with a green arrow printed on top. Pry from the side the arrow is pointing with your fingers.
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
  8. Pull the motherboard up from the side opposite the loose flex cable.
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
결론
Angelica Macrohon
회원 가입일: 2013년 10월 16일
267 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G32
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 48
