주요 콘텐츠로 건너뛰기
Samsung Sway Motherboard Replacement
필요한 것
  1. Samsung Sway Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Samsung Sway Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Samsung Sway Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Using your thumb(s) slide the cover up to remove
    • Remove the battery by using your finger either in the upper left or right corner
  2. Samsung Sway Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the four corner .4cm Phillips head screws.
  3. Samsung Sway Motherboard Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
  4. Samsung Sway Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew the two .4 cm Phillips head screws from under the Samsung logo
  5. Samsung Sway Motherboard Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off. Being careful of the side buttons that pop off.
  6. Samsung Sway Motherboard Replacement: 6 단계, 이미지 1/1
    • Grasp the sides of the motherboard and gently rock back and forth . This is due to the sticky tape that is on the battery
  7. Samsung Sway Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the black serial cable from the mother board.
  8. Samsung Sway Motherboard Replacement: 8 단계, 이미지 1/1
    • Gently pull of the antenna sticker tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Rush
회원 가입일: 06/27/13
306 평판
안내서 3개 작성하였습니다
WRI115, Team 1-2, Ruszkiewicz Spring 2013 WRI115, Team 1-2, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 443
