주요 콘텐츠로 건너뛰기
Samsung Sway Rear Cover Replacement
필요한 것
  1. Samsung Sway Rear Cover Replacement, Rear cover: 1 단계, 이미지 1/1
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: 2 단계, 이미지 1/2 Samsung Sway Rear Cover Replacement: 2 단계, 이미지 2/2
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: 3 단계, 이미지 1/2 Samsung Sway Rear Cover Replacement: 3 단계, 이미지 2/2
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: 4 단계, 이미지 1/1
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: 5 단계, 이미지 1/1
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: 6 단계, 이미지 1/1
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
결론
Chris Rush
회원 가입일: 06/27/13
306 평판
안내서 3개 작성하였습니다
WRI115, Team 1-2, Ruszkiewicz Spring 2013 WRI115, Team 1-2, Ruszkiewicz Spring 2013 회원
WRI115-RUSZKIEWICZ-S13S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 258
