필요한 것
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Remove the 3 screws located around the motherboard. 2 screws are located on the left side and1 screw is located on the right side.
다른 한 분이 해당 안내서를 완성하였습니다.
