주요 콘텐츠로 건너뛰기
Samsung U28E510 Jog Button Replacement
필요한 것
  1. Samsung U28E510 Jog Button Replacement, Jog Button: 1 단계, 이미지 1/3 Samsung U28E510 Jog Button Replacement, Jog Button: 1 단계, 이미지 2/3 Samsung U28E510 Jog Button Replacement, Jog Button: 1 단계, 이미지 3/3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: 2 단계, 이미지 1/2 Samsung U28E510 Jog Button Replacement: 2 단계, 이미지 2/2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: 3 단계, 이미지 1/1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
결론
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
다른 3명이 해당 안내서를 완성하였습니다.
Jake Ritter
회원 가입일: 01/22/18
106 평판
안내서 1개 작성함
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G1
4 회원들
안내서 6개 작성하였습니다
댓글 5개
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - 답글
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - 답글
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - 답글
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 62
전체 시간: 6,679
