주요 콘텐츠로 건너뛰기
Samsung U28E510 Low Voltage Display Signal Board Replacement
필요한 것
  1. Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 1 단계, 이미지 1/3 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 1 단계, 이미지 2/3 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 1 단계, 이미지 3/3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Low Voltage Display Signal Board Replacement: 2 단계, 이미지 1/2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 2 단계, 이미지 2/2
    • Flip the monitor over so that it is face down.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Low Voltage Display Signal Board.
  3. Samsung U28E510 Low Voltage Display Signal Board Replacement: 3 단계, 이미지 1/2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 3 단계, 이미지 2/2
    • Remove the 4 holding screws using a #0 Phillips screwdriver.
    • Lift the cover to expose the LVDS Board while taking care to prevent removal of the white fogged plastic cover. This plastic cover keeps the wire ribbons safe from accidental damage.
  4. Samsung U28E510 Low Voltage Display Signal Board Replacement: 4 단계, 이미지 1/2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 4 단계, 이미지 2/2
    • Disconnect the input signal ribbon cable from the top of the board.
    • Disconnect the output signal ribbon cables by using a plastic sprudger to lift the connection lock.
    • Remove and replace the LVDS Board.
결론
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around the monitor.
Raymundo Calderon-Robles
회원 가입일: 01/22/18
306 평판
안내서 1개 작성함
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,037
