소개
This guide will assist you to open up the monitor and remove the motherboard. Useful if the monitor does not power on after replacing power supply, or is turning on/ off repeatedly.
필요한 것
Start by removing the screen bezel.
Use a pair of spudgers to pry between the cover and the rest of the monitor.
Lay monitor on its back and pull off screen cover.
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
다른 3명이 해당 안내서를 완성하였습니다.
