이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start by removing the screen bezel.
Use a pair of spudgers to pry between the cover and the rest of the monitor.
Lay monitor on its back and pull off screen cover.
Flip the monitor over so that it is facedown.
Remove the single screw in the middle using a #2 Phillips screwdriver.
Remove backing to reveal signal/power board in center.
Unplug wires connected to supply (one on the left and one on right).
Disconnect the signal ribbon cable.
Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
Lay piece upside down.
Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
Lift the motherboard out of the metal shield.
다른 3명이 해당 안내서를 완성하였습니다.
