주요 콘텐츠로 건너뛰기
Samsung UBD KM85C Outer Shell Replacement
필요한 것
  1. Samsung UBD KM85C Outer Shell Replacement, Outer Shell: 1 단계, 이미지 1/1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD KM85C Outer Shell Replacement: 2 단계, 이미지 1/2 Samsung UBD KM85C Outer Shell Replacement: 2 단계, 이미지 2/2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD KM85C Outer Shell Replacement: 3 단계, 이미지 1/3 Samsung UBD KM85C Outer Shell Replacement: 3 단계, 이미지 2/3 Samsung UBD KM85C Outer Shell Replacement: 3 단계, 이미지 3/3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD KM85C Outer Shell Replacement: 4 단계, 이미지 1/1
    • Remove the cover from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Breanna Ainsworth
회원 가입일: 01/30/18
258 평판
안내서 1개 작성함
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 222
