주요 콘텐츠로 건너뛰기
Samsung UBD-K8500 Circuit Board Replacement
필요한 것
  1. Samsung UBD-K8500 Circuit Board Replacement, Top Panel: 1 단계, 이미지 1/2 Samsung UBD-K8500 Circuit Board Replacement, Top Panel: 1 단계, 이미지 2/2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Circuit Board Replacement: 2 단계, 이미지 1/2 Samsung UBD-K8500 Circuit Board Replacement: 2 단계, 이미지 2/2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Circuit Board Replacement, Circuit Board: 3 단계, 이미지 1/1
    • Using your fingers, carefully pinch the clipping part of the four connectors and gently pull them out of their sockets.
  4. Samsung UBD-K8500 Circuit Board Replacement: 4 단계, 이미지 1/2 Samsung UBD-K8500 Circuit Board Replacement: 4 단계, 이미지 2/2
    • Gently pull out the two blue tabs of the ribbon connectors.
  5. Samsung UBD-K8500 Circuit Board Replacement: 5 단계, 이미지 1/2 Samsung UBD-K8500 Circuit Board Replacement: 5 단계, 이미지 2/2
    • Remove the three 7 mm screws from the circuit board using a Phillips #0 screwdriver.
  6. Samsung UBD-K8500 Circuit Board Replacement: 6 단계, 이미지 1/2 Samsung UBD-K8500 Circuit Board Replacement: 6 단계, 이미지 2/2
    • Gently pull out the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Syeda Zainab
회원 가입일: 09/12/23
264 평판
안내서 2개 작성하였습니다
University of North Texas, Team 2-7, Harold Fall 2023 University of North Texas, Team 2-7, Harold Fall 2023 회원
UNT-HAROLD-F23S2G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 117
