소개
This guide will help you replace the circuit board for the Samsung UBD-K8500. If your circuit board becomes faulty after exposure to heat, an impact, power surges or overloads, access this guide to replace the defective circuit board. A fragmented connection from the motherboard to the daughter board may cause glitches and errors in reading discs.
필요한 것
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Using your fingers, carefully pinch the clipping part of the four connectors and gently pull them out of their sockets.
다른 한 분이 해당 안내서를 완성하였습니다.
