주요 콘텐츠로 건너뛰기
Samsung UBD-KM85C Disc Drive Replacement
필요한 것
  1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: 1 단계, 이미지 1/1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C Disc Drive Replacement: 2 단계, 이미지 1/2 Samsung UBD-KM85C Disc Drive Replacement: 2 단계, 이미지 2/2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C Disc Drive Replacement: 3 단계, 이미지 1/3 Samsung UBD-KM85C Disc Drive Replacement: 3 단계, 이미지 2/3 Samsung UBD-KM85C Disc Drive Replacement: 3 단계, 이미지 3/3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C Disc Drive Replacement: 4 단계, 이미지 1/1
    • Remove the cover from the device.
  5. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: 5 단계, 이미지 1/1
    • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
  6. Samsung UBD-KM85C Disc Drive Replacement: 6 단계, 이미지 1/2 Samsung UBD-KM85C Disc Drive Replacement: 6 단계, 이미지 2/2
    • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
  7. Samsung UBD-KM85C Disc Drive Replacement: 7 단계, 이미지 1/3 Samsung UBD-KM85C Disc Drive Replacement: 7 단계, 이미지 2/3 Samsung UBD-KM85C Disc Drive Replacement: 7 단계, 이미지 3/3
    • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
  8. Samsung UBD-KM85C Disc Drive Replacement: 8 단계, 이미지 1/1
    • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Edwards
회원 가입일: 02/01/18
627 평판
안내서 5개 작성하였습니다
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 375
