주요 콘텐츠로 건너뛰기
Samsung UBD-KM85C Fan B Replacement
필요한 것
  1. Samsung UBD-KM85C Fan B Replacement, Outer Shell: 1 단계, 이미지 1/1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C Fan B Replacement: 2 단계, 이미지 1/2 Samsung UBD-KM85C Fan B Replacement: 2 단계, 이미지 2/2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C Fan B Replacement: 3 단계, 이미지 1/3 Samsung UBD-KM85C Fan B Replacement: 3 단계, 이미지 2/3 Samsung UBD-KM85C Fan B Replacement: 3 단계, 이미지 3/3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C Fan B Replacement: 4 단계, 이미지 1/1
    • Remove the cover from the device.
  5. Samsung UBD-KM85C Fan B Replacement, Fan B: 5 단계, 이미지 1/2 Samsung UBD-KM85C Fan B Replacement, Fan B: 5 단계, 이미지 2/2
    • Using a #1 phillips head screwdriver, remove the two 8.1 mm screws in the corners of the fan.
  6. Samsung UBD-KM85C Fan B Replacement: 6 단계, 이미지 1/3 Samsung UBD-KM85C Fan B Replacement: 6 단계, 이미지 2/3 Samsung UBD-KM85C Fan B Replacement: 6 단계, 이미지 3/3
    • Use your fingers to pinch the white tip of the multicolored wire connecting the fan to the motherboard. While pinching, gently pull up to remove the wires from the motherboard.
  7. Samsung UBD-KM85C Fan B Replacement: 7 단계, 이미지 1/1
    • The fan is now free from its screws and wire and can be freely lifted out of the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Edwards
회원 가입일: 02/01/18
627 평판
안내서 5개 작성하였습니다
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 258
