주요 콘텐츠로 건너뛰기
Samsung UBD-KM85C WiFi Module Replacement
필요한 것
  1. Samsung UBD-KM85C WiFi Module Replacement, Outer Shell: 1 단계, 이미지 1/1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C WiFi Module Replacement: 2 단계, 이미지 1/2 Samsung UBD-KM85C WiFi Module Replacement: 2 단계, 이미지 2/2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C WiFi Module Replacement: 3 단계, 이미지 1/3 Samsung UBD-KM85C WiFi Module Replacement: 3 단계, 이미지 2/3 Samsung UBD-KM85C WiFi Module Replacement: 3 단계, 이미지 3/3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C WiFi Module Replacement: 4 단계, 이미지 1/1
    • Remove the cover from the device.
  5. Samsung UBD-KM85C WiFi Module Replacement, WiFi Module: 5 단계, 이미지 1/2 Samsung UBD-KM85C WiFi Module Replacement, WiFi Module: 5 단계, 이미지 2/2
    • The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
  6. Samsung UBD-KM85C WiFi Module Replacement: 6 단계, 이미지 1/3 Samsung UBD-KM85C WiFi Module Replacement: 6 단계, 이미지 2/3 Samsung UBD-KM85C WiFi Module Replacement: 6 단계, 이미지 3/3
    • There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
  7. Samsung UBD-KM85C WiFi Module Replacement: 7 단계, 이미지 1/3 Samsung UBD-KM85C WiFi Module Replacement: 7 단계, 이미지 2/3 Samsung UBD-KM85C WiFi Module Replacement: 7 단계, 이미지 3/3
    • Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Edwards
회원 가입일: 02/01/18
627 평판
안내서 5개 작성하였습니다
Baylor, Team S2-G1, Johnson Spring 2018 Baylor, Team S2-G1, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 565
