주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung WB150F Motherboard Replacement
필요한 것
  1. Samsung WB150F Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The location of the battery compartment can be found on the underside of the camera.
  2. Samsung WB150F Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung WB150F Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
  3. Samsung WB150F Motherboard Replacement, LCD Screen: 3 단계, 이미지 1개 중 1개
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  4. Samsung WB150F Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung WB150F Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung WB150F Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  5. Samsung WB150F Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Your camera should now look like the camera in the photo.
  6. Samsung WB150F Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Samsung WB150F Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  7. Samsung WB150F Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Samsung WB150F Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Samsung WB150F Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  8. Samsung WB150F Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Samsung WB150F Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Samsung WB150F Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
  9. Samsung WB150F Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 Samsung WB150F Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 Samsung WB150F Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
    • Disconnect the ribbon from the flash assembly.
    • Disconnect two ribbons from the lens assembly as shown in the second picture.
    • Disconnect the ground wire from the motherboard as shown in the third picture.
  10. Samsung WB150F Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Samsung WB150F Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard from the camera housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Wyatt Turner
회원 가입일: 04/12/22
268 평판
안내서 3개를 작성함
IUPUI, Team 7-7, Beck Spring 2022 IUPUI, Team 7-7, Beck Spring 2022 회원
IUPUI-BECK-S22S7G7
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 631
