주요 콘텐츠로 건너뛰기
Samsung WB2100 Back Cover Assembly Replacement
필요한 것
  1. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 1 단계, 이미지 1/3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 1 단계, 이미지 2/3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 1 단계, 이미지 3/3
    • Remove the 7 screws on the outside of the camera
    • Two 5 mm PH000 screws on the right side of the camera body
    • Four 3mm PH000 screws on the bottom and the left side of the camera body.
    • Use the plastic spundger to push the back casing out. Start from the right side and work your way clockwise around the case.
    • The HDMI / AV tab might fall out. this is supposed to happen as it is not screwed into place in the back casing.
  2. Samsung WB2100 Back Cover Assembly Replacement: 2 단계, 이미지 1/2 Samsung WB2100 Back Cover Assembly Replacement: 2 단계, 이미지 2/2
    • Disconnect the set of wires from the back casing to the motherboard. Do this by using the plastic spundger to flip the black tab up and the wires will pull out.
    • Unscrew the four 3 mm and two silver 1 mm PH000 screw from the green logic board
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mason Ricks
회원 가입일: 01/20/16
282 평판
안내서 2개 작성하였습니다
USF Tampa, Team 15-3, Remmell Spring 2016 USF Tampa, Team 15-3, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 361
