소개
This is a prerequisite guide to take off the back cover assembly.
필요한 것
Remove the 7 screws on the outside of the camera
Two 5 mm PH000 screws on the right side of the camera body
Four 3mm PH000 screws on the bottom and the left side of the camera body.
Use the plastic spundger to push the back casing out. Start from the right side and work your way clockwise around the case.
다른 한 분이 해당 안내서를 완성하였습니다.
