주요 콘텐츠로 건너뛰기
Samsung WB2200F Record Button Replacement
필요한 것
  1. Samsung WB2200F Record Button Replacement, Face-plate: 1 단계, 이미지 1/3 Samsung WB2200F Record Button Replacement, Face-plate: 1 단계, 이미지 2/3 Samsung WB2200F Record Button Replacement, Face-plate: 1 단계, 이미지 3/3
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  2. Samsung WB2200F Record Button Replacement: 2 단계, 이미지 1/1
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  3. Samsung WB2200F Record Button Replacement: 3 단계, 이미지 1/1
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  4. Samsung WB2200F Record Button Replacement, Record Button: 4 단계, 이미지 1/1
    • Open up the camera by removing the four 6 mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
  5. Samsung WB2200F Record Button Replacement: 5 단계, 이미지 1/1
    • Gently lift off the metal cover.
  6. Samsung WB2200F Record Button Replacement: 6 단계, 이미지 1/1
    • Clean out any dust or debris from the button interface.
    • Replace faulty button.
결론
Rudolf Boampong
회원 가입일: 03/04/16
195 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 214
