주요 콘텐츠로 건너뛰기
Samsung WB350F Rear Case Replacement
필요한 것
  1. Samsung WB350F Rear Case Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung WB350F Rear Case Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung WB350F Rear Case Replacement, Rear Case: 1 단계, 이미지 3/3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: 2 단계, 이미지 1/3 Samsung WB350F Rear Case Replacement: 2 단계, 이미지 2/3 Samsung WB350F Rear Case Replacement: 2 단계, 이미지 3/3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: 3 단계, 이미지 1/3 Samsung WB350F Rear Case Replacement: 3 단계, 이미지 2/3 Samsung WB350F Rear Case Replacement: 3 단계, 이미지 3/3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: 4 단계, 이미지 1/1
    • Remove the plastic casing, exposing the inner workings of the camera.
결론
Zachary Bourgault
회원 가입일: 03/04/16
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 718
