주요 콘텐츠로 건너뛰기
Samsung WB350F Screen Replacement
필요한 것
  1. Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung WB350F Screen Replacement, Rear Case: 1 단계, 이미지 3/3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Screen Replacement: 2 단계, 이미지 1/3 Samsung WB350F Screen Replacement: 2 단계, 이미지 2/3 Samsung WB350F Screen Replacement: 2 단계, 이미지 3/3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Screen Replacement: 3 단계, 이미지 1/3 Samsung WB350F Screen Replacement: 3 단계, 이미지 2/3 Samsung WB350F Screen Replacement: 3 단계, 이미지 3/3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Screen Replacement: 4 단계, 이미지 1/1
    • Remove the plastic casing, exposing the inner workings of the camera.
  5. Samsung WB350F Screen Replacement, Screen: 5 단계, 이미지 1/2 Samsung WB350F Screen Replacement, Screen: 5 단계, 이미지 2/2
    • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
    • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
  6. Samsung WB350F Screen Replacement: 6 단계, 이미지 1/1
    • Move the menu button panel to the right as well as the screen.
    • Be careful because each are connected to the camera by a ribbon.
  7. Samsung WB350F Screen Replacement: 7 단계, 이미지 1/1
    • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
  8. Samsung WB350F Screen Replacement: 8 단계, 이미지 1/2 Samsung WB350F Screen Replacement: 8 단계, 이미지 2/2
    • Remove the silver panel.
  9. Samsung WB350F Screen Replacement: 9 단계, 이미지 1/2 Samsung WB350F Screen Replacement: 9 단계, 이미지 2/2
    • Flip the screen back over.
    • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
  10. Samsung WB350F Screen Replacement: 10 단계, 이미지 1/2 Samsung WB350F Screen Replacement: 10 단계, 이미지 2/2
    • Carefully detach both ribbons by gently pulling one at a time.
    • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
    • Be sure to pull gently as you do not want to break either ribbon.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Casey Bernier
회원 가입일: 03/04/16
131 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G2
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 30
전체 시간: 1,445
