주요 콘텐츠로 건너뛰기
Samsung WB850F Control Panel Replacement
필요한 것
  1. Samsung WB850F Control Panel Replacement, Control Panel: 1 단계, 이미지 1/3 Samsung WB850F Control Panel Replacement, Control Panel: 1 단계, 이미지 2/3 Samsung WB850F Control Panel Replacement, Control Panel: 1 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: 2 단계, 이미지 1/1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: 3 단계, 이미지 1/2 Samsung WB850F Control Panel Replacement: 3 단계, 이미지 2/2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
결론
Jousling Vazquez
회원 가입일: 02/08/16
431 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-4, Eyestone Spring 2016 USF Tampa, Team 12-4, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G4
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Only problem .. Where can I buy a replacement control panel.
D Traynor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 13
전체 시간: 704
