필요한 것
Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
