주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
SanDisk Sansa C250 Rear Case Cover Replacement
필요한 것
  1. SanDisk Sansa C250 Rear Case Cover Replacement, Battery Cover: 1 단계, 이미지 1/1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Rear Case Cover Replacement: 2 단계, 이미지 1/1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Rear Case Cover Replacement, Battery: 3 단계, 이미지 1/1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Rear Case Cover Replacement: 4 단계, 이미지 1/1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Rear Case Cover Replacement: 5 단계, 이미지 1/1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Rear Case Cover Replacement, Rear Case Cover: 6 단계, 이미지 1/1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Rear Case Cover Replacement: 7 단계, 이미지 1/1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Rear Case Cover Replacement: 8 단계, 이미지 1/1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Rear Case Cover Replacement: 9 단계, 이미지 1/1
    • The rear case cover can now be separated from the device.
결론
Nicolas Coffey
회원 가입일: 01/27/12
43 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-30, Amido Winter 2012 Cal Poly, Team 3-30, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G30
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 851
