주요 콘텐츠로 건너뛰기
SanDisk Wireless Stick 16 GB Disassembly
필요한 것
  1. SanDisk Wireless Stick 16 GB Disassembly, Presentation: 1 단계, 이미지 1/1
    • This is a 16Gb SanDisk Wireless Stick key for use in a traditional USB flash drive and content sharing via Wifi.
  2. SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: 2 단계, 이미지 1/3 SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: 2 단계, 이미지 2/3 SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: 2 단계, 이미지 3/3
    • Remove the plastic around the USB port by unclipping it.
    • Then remove the plastic covering the key (also clipped on).
    • You will now be able to remove the electronic card from the lower plastic.
    • Be careful: Avoid pressing the side button when handling to avoid turning on the WiFi.
  3. SanDisk Wireless Stick 16 GB Disassembly, Lift the metal adhesive: 3 단계, 이미지 1/1
    • Peel off the metal adhesive starting from one side.
    • The SD card, which serves as an internal memory, is now visible.
    • On the left side of the picture you can see the WiFi AirStash module (metal plate).
  4. SanDisk Wireless Stick 16 GB Disassembly, Remove the SD card: 4 단계, 이미지 1/1
    • Use a plastic tool to push the SD card towards the USB port (using the offset on the side of the card).
    • Once shifted to the maximum, you can then take out the SD card by lifting the side opposite to the USB port.
결론
To reassemble your device, follow the instructions of this guide in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Louis Perez
회원 가입일: 04/12/17
281 평판
안내서 1개 작성함
댓글 5개
I replaced the microsd with a faster one with a hope to get a faster transfer speed and found out that the device wont boot properly after replacing the card with the same capacity, same file system(FAT32) card.
I got it working properly by copying a whole disk image from the original card and burning it to the new card.
Maybe there is a invisible file inside the card that tells the device whether the card is genuine or not.
yusuke kikuchi - 답글
please could you share your disk image file because i formated my card by accident and now it wont read write or even boot
Mohamed Hesham -
Which app did you used to copy the sd card image? Can you also upgrade from 16GB to like 200GB? Seems there are 2 different firmware files on Sandisk site.
makaiandras84 - 답글
What if you format the card using these instructions?
https://kb.sandisk.com/app/answers/detai...
Timothy James Dimacali - 답글
Alex H - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 56
전체 시간: 6,899
