주요 콘텐츠로 건너뛰기
Sandal Brooch Replacement
필요한 것
  1. Sandal Brooch Replacement, Brooch: 1 단계, 이미지 1/3 Sandal Brooch Replacement, Brooch: 1 단계, 이미지 2/3 Sandal Brooch Replacement, Brooch: 1 단계, 이미지 3/3
    • Unwind about 10" of thread. Cut and thread through the needle. Tie a double knot at the end of the thread.
  2. Sandal Brooch Replacement: 2 단계, 이미지 1/2 Sandal Brooch Replacement: 2 단계, 이미지 2/2
    • The threads and empty holes show exactly where to attach the shoe ornament.
    • Cut off the old threads.
  3. Sandal Brooch Replacement: 3 단계, 이미지 1/2 Sandal Brooch Replacement: 3 단계, 이미지 2/2
    • Start the threaded needle on the upper side of the sandal.
    • The ornament will hide the knot.
    • If pushing the needle through the sandal strap is difficult, you might try turning the sandal at an angle and using your flat surface as a pressing point.
  4. Sandal Brooch Replacement: 4 단계, 이미지 1/1
    • Pull the thread through the ornament's opening.
    • Be careful—needles are sharp!
  5. Sandal Brooch Replacement: 5 단계, 이미지 1/3 Sandal Brooch Replacement: 5 단계, 이미지 2/3 Sandal Brooch Replacement: 5 단계, 이미지 3/3
    • Pull the thread down and through the sandal straps.
    • Repeat the process, catching the ornament in a variety of places to anchor several sides.
  6. Sandal Brooch Replacement: 6 단계, 이미지 1/2 Sandal Brooch Replacement: 6 단계, 이미지 2/2
    • Pull the thread so that the ornament is tight against the sandal.
    • Remember to beware of that sharp needle!
  7. Sandal Brooch Replacement: 7 단계, 이미지 1/1
    • Run the needle back through the sandal strap, then tie a knot at the base of the thread.
    • Double the knot before using your scissors to cut the thread.
    • Cut the thread just above the knot.
    • Be careful—scissors are sharp.
  8. Sandal Brooch Replacement: 8 단계, 이미지 1/1
    • Completed sandal—ready to wear!
결론
Enjoy wearing the sandals!
KaC
회원 가입일: 08/27/23
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 98
