이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
You now have access to all components found on the inside of the device!
Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
Use soldering iron to melt the existing solder at the three headphone jack connections.
Align the new headphone jack appropriately on the motherboard for soldering.
Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
Allow the new solder to cool and harden before reassembling the MP3 player.
