필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
You now have access to all components found on the inside of the device!
