주요 콘텐츠로 건너뛰기
Sanitaire SC684 Back Wheels Replacement
필요한 것
  1. Sanitaire SC684 Back Wheels Replacement, Back Wheels: 1 단계, 이미지 1/1
    • Be sure to unplug the vacuum before disassembling to prevent electric shock.
    • Lay the vacuum on its side.
    • Remove the two screws with the Phillips #1 screwdriver that are securing the axle of the back wheels.
    • Repeat for the other wheel.
  2. Sanitaire SC684 Back Wheels Replacement: 2 단계, 이미지 1/1
    • Pull the wheel's axle towards you and replace back wheels.
    • The wheels come as a unit with the wheel's axle.
결론
Caycie Pascual
회원 가입일: 09/26/12
1 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-58, Forte Fall 2012 Cal Poly, Team 16-58, Forte Fall 2012 회원
CPSU-FORTE-F12S16G58
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 880
